Posted by dej(Jed) on August 22, 2012 at 05:31:18 from (141.189.251.1):
In Reply to: Fuel in crankcase oil posted by WVFarmall on August 21, 2012 at 18:03:30:
It depends on how much fuel in oil you are talking about. Fuel in oil dillution occurs every time you start up. It is worse in the winter when you crank the engine a lot. You always get some fuel, gasoline or diesel, that gets sent into the engine oil. Pump seals and bad rings are the most common problems when you have severe dillution.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
