Re: Large IH Disk Plow. [pic]
Posted by agpilot on August 22, 2012 at 05:36:55 from (50.33.3.49):
In Reply to: Large IH Disk Plow. [pic] posted by Don L. on August 20, 2012 at 10:20:51:
Don: We had one but it was 4 bottom. In SW Mn wher the land had slight rolling hills is would not go straight across a field due to different soil weight. (Wider cut on lower ground) Pulled real easy with S-MD. Could have used 3ed gear but would throw the dirt too far.. It cut trash and buried it fairly good and there wern't many high clearance moldboards built yet at that time. By your pictures I will have to guess someone took a bottom or two off.. Because it would not plow in a straight line, I ended up using it the most. My farher had to plow in a straight line.
