Re: EXHAUST PIPE ON A M
Posted by GordoSD on August 22, 2012 at 17:06:13 from (64.33.250.162):
In Reply to: Re: EXHAUST PIPE ON A M posted by SDE on August 22, 2012 at 14:22:02:
No, bad advice. Muffler pipe can't be threaded into the manifold.
Remove manifold from motor.Cut the old pipe off about 3/4 inch above the manifold. Use your asawsall. Now make a cut parrallel to the pipe sides doan into the manifold. Cut just barely into the threads. One cut.
Use punch and collapse the pipe and pull it out. Maximum 15 minute job.
2 inch npt to retap. Blow out all grit and metal. Reinstall new 2 inch pipe about 12 inchesl long.
