Re: ampmeter seems shot ...12 v conversion?
Posted by rustred on August 22, 2012 at 17:27:06 from (184.151.222.60):
In Reply to: Re: ampmeter seems shot ...12 v conversion? posted by realolman on August 22, 2012 at 17:15:49:
to see if the ampmeter is working when off you need to have pos. post disconnected from batt. and touch one post to the pos. on batt. and the other post to the cable. it will show charge if tractor is chargeing. but you need to do this on a tractor that has a working charging system .
and if the ampmeter is backwards on tractor it will show discharge. it will not cause a no charge situation if the ampmeter is good.
