> The posts to which the wires connect are > connected to a piece of aluminum that is bent > and routed down around I guess a magnet, that > rotates on a little shaft allowing the magnet > and attached pointer to rotate...
Yes, that"s how an ammeter works. The magnetic field created by the current through the bit of aluminum exerts torque on the magnet.
> ...no connection.
What do you mean by that?
> ...hooked up a couple wires and > touched it to the battery posts...
You connected one terminal of the ammeter directly to the battery negative post and the other directly to the positive? If the meter wasn"t fried before it is now.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
