Posted by Janicholson on August 22, 2012 at 18:33:06 from (96.24.99.126):
In Reply to: oil pan off posted by tuckaway on August 22, 2012 at 16:03:29:
With the pan off, checking the center main bearing with plastigauge, and the rod bearings as well seems reasonable.. if they are at or less than .003" I would button it up and run it. if larger, I would probably remove the engine and put new lower end bearings in it. The rod bearings can be changed W/O removing the engine, but the rear main cannot. If plastigauging, be sure to hold the weight of the crank upward to prevent its weight from smashing the "noodle" of plastigauge when doing the main/s. Use just enough lift to hold the crank upward. Depending on engine series there are probably no cam bearings. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
