Re: Crank journal diameter ?
Posted by hendrik on October 09, 2000 at 22:58:18 from (194.53.253.50):
In Reply to: Crank journal diameter ? posted by Ralph Kramden on October 09, 2000 at 16:04:29:
Hello Ralph. I could look up the crank diameters, but the bearing size you have to order also depends on whether or not your engine has had a previous overhaul. If undersize bearings are present you will have to order these again, provided the journals need no grinding... My advice is to remove the bearing caps first and see what you've got. Regards, Hendrik.
Post A Followup
: Re: Re: Crank journal diameter ?
