Re: Mcormick W-30 Radiator to Engine Connection
Posted by robgIN on August 23, 2012 at 04:47:43 from (76.208.5.124):
In Reply to: Mcormick W-30 Radiator to Engine Connection posted by BunkumBen on August 23, 2012 at 04:05:51:
I wouldn't reccomend shimming the motor mount as you will put the driveline in a bind if you do, Try to do your adjustmenys with the water outlets
