Posted by Travis Miranowski on August 23, 2012 at 10:45:46 from (67.5.42.20):
In Reply to: ih hit and miss posted by b-rad on August 22, 2012 at 15:40:09:
A hit and miss engine also has a governer but instead of moving the throttle plate, it latches out the exhaust valve to make the engine coast until it reaches a lower speed then unlatches to make the engine hit and the cycle continues. Your LB engine is a throttle governed engine. I have never seen the throttle shaft break, but what I have seen is the coupler between the rear shaft and throttle shaft in the head break. They are made of 4 small pieces of metal welded in the center about 1 1/2 long. It pulls out after the head is off.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
