Re: Farmall 350 Eletrical problem
Posted by Brownie 450 on August 23, 2012 at 14:54:22 from (66.43.241.198):
In Reply to: Farmall 350 Eletrical problem posted by dhermesc on August 23, 2012 at 10:07:43:
Next time it happens, with tractor in neutral. try shorting across the large batt terminal & the smaller wire going to the "s" terminal on the solenoid. Nothing here?? short across the 2 large terminals on the solenoid to see if the starter turns. If nothing happens in both cases, look for ground or batt terminal problems [loose/ corroded].
