Re: 400 diesel...........again
Posted by Janicholson on August 23, 2012 at 18:10:40 from (67.72.98.45):
In Reply to: 400 diesel...........again posted by J inPa on August 23, 2012 at 18:04:15:
They rotate in opposite directions. The guts from the diesel, put into the other housings is OK. The shaft needs to be checked to assure it is not worn. A longer bushing can be used to touch the shaft in an unworn spot. Make sure the components are assembled correctly, and keep it in time (#1 on tdc etc. Jim
