Re: Installation of 504 power steering cylinder seal kit
Posted by FBH44 on August 24, 2012 at 10:43:35 from (64.85.221.243):
In Reply to: Installation of 504 power steering cylinder seal kit posted by Red Mercury on August 23, 2012 at 22:24:05:
My Case-IH dealer is about a mile away, I stopped in again on my way to town. The old experienced counter man veified what I said earlier; the open-side of the seal, the part that can be filled with grease or pressure oil, should face inboard. The grease or pressure will cause the seal to press inwards and grab onto the shaft. In other words, from outside, a person should see your top picture.
