Cub Headlights
Posted by dougct on August 24, 2012 at 11:37:19 from (50.138.242.44):
My 50 Cub has a headlight issue.They all work front and rear also high and low,but the low"s are dim and the highbeam is more like a low but the rear works good.If i grab either front light when it"s on it seems to brighten up some.I tryed sanding the ground on the inside for a better contact.Could it be the place they are mounted to??it must be a bad ground??any ideas?
