Re: Clutch, Super H
Posted by mkirsch on August 24, 2012 at 11:39:17 from (64.80.110.74):
In Reply to: Clutch, Super H posted by Wilfam on August 24, 2012 at 10:42:10:
If it were stuck in two gears, the tractor would not move at all.
Fiddling with the M&W clutch makes the tractor move. That is where the problem is.
For the tractor to move both the foot clutch and the M&W must be engaged. Foot off the pedal, and hand lever forward.
AFAIK, you can lock up the clutches on the M&W by taking the cover off and tightening the large nut underneath. This will effectively disable the M&W clutch's ability to stop the tractor while leaving the PTO running. Pulling the lever will do nothing.
I have the same clutch on my Super M, but I am still trying to figure out how it works, how it adjusts, and if it's even any good. Right now nothing happens when I pull the lever 9 times out of 10.
