Re: Plowing with my 560D
Posted by Lmack on August 24, 2012 at 14:24:09 from (24.131.58.167):
In Reply to: Re: Plowing with my 560D posted by slifnom on August 24, 2012 at 13:14:33:
The plow has to swing freely from side to side to run a direct mount plow with the two point hitch(especially if the furrow is curved). There are two stabilizer pins that have to be pulled and moved to storage slots to allow the movement. I am not sure about the 560 set up having run other models, but it has to be done. You also remove the pins to operate a colter guided cultivator frame. Check with your operators manual.
