Re: Clutch, Super H
Posted by Ol' Gimpy on August 24, 2012 at 16:20:29 from (74.67.127.235):
In Reply to: Clutch, Super H posted by Wilfam on August 24, 2012 at 10:42:10:
A guess would be the tabs holding the adjusting nut have sheared,letting the adjustment nut back off.Usually happens when the Aetna bearing seizes from no lubrication.Wasn"t uncommon to get Farmalls in that had the M&W clutch unit welded together,or remove the units altogether if that problem occured,and the owners no longer used the M&W unit.Had a number of them lying around back then,should have held on to them!!
