Re: Farmall 450 re-wiring
Posted by charlieu on August 24, 2012 at 16:42:38 from (206.53.193.95):
In Reply to: Farmall 450 re-wiring posted by P and R Pete on August 24, 2012 at 10:22:42:
Removing the three bolts that hold the shifter lever to the top of the transmission will give you lot's of room after you get the lever out of the way.
