Re: Wouldn't this be a work horse pic
Posted by Armand Tatro on August 24, 2012 at 16:42:54 from (98.227.26.140):
In Reply to: Wouldn't this be a work horse pic posted by kennell on August 24, 2012 at 05:12:13:
A few minutes after I posted my first post I got to thinking (I know: That is always scary!). A tractor without implements (mounted or trailing) and pto and/or belt pulley to power attatchments plus hydraulics or power lifts (factory made or after market) a tractor would be pretty worthless! Armand
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
