Re: Farmall 140 steering
Posted by Janicholson on August 24, 2012 at 20:54:18 from (96.24.99.126):
In Reply to: Farmall 140 steering posted by Eugene Thompson on August 24, 2012 at 19:49:41:
Block it under the torque tube (bell housing) to remove weight with wooden cribbing. Take pictures before, and as you go along, more is better. Heavy things like axles and castings must be supported from the top (balanced). Drain fluids before opening hoses. Don't twist off bolts, they remove easiest when they still have heads on them!!! Follow the procedure. Jim
