I believe you are right. I wanted to put the seal in like a normal oil seal (lip inwards) but that side of the outer metal rim is cut very square so it didn't look like it was going to go. I did a little internet detective work after I read your reply. Turns out it is exactly as you said--a wiper seal to keep debris from getting to the main seal which is an O-ring & back up washer. I pressed the seals in tonight--it's all good. Thanks for your help!
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
