Re: Remove gas tank from 1948 H Farmall
Posted by FBH44 on August 25, 2012 at 03:16:00 from (64.85.216.16):
In Reply to: Remove gas tank from 1948 H Farmall posted by Dwight Wullweber on August 24, 2012 at 18:20:12:
If you"ll look at the steering wheel post, there might be a dent in it, where the tank flange meets. Apparently a lot of H"s had a slight design interference, the tank was just a little bit too long to fit so they just dented the post to git itin. Might be a tight fit. And that tank is real heavy, like Henry said. .
