Posted by Janicholson on August 25, 2012 at 05:26:43 from (96.24.99.126):
In Reply to: Farmall 350 starter posted by Allnightshifter2 on August 24, 2012 at 23:41:21:
The others are correct. Rocking it requires High gear (5th) and direct drive, not TA back. The rocking is violent and results in engine movement sufficient to dislodge the drive. Loosening is directly effective. At this point the drive should be replaced with a newer style that has a much smaller pull in spring, and which does not drive through that spring. It can be found on many sites, and, if the ring gear is usable (probable with a little careful filing to remove burrs) go for it. THe new drive is not expensive. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
