Posted by gamehunter56474 on August 25, 2012 at 09:39:14 from (96.60.152.38):
I recently purchased a live power pump with manifold and distributor included from ebay for $75. Not knowing if it was a good, functional unit I installed it, and it works perfectly. Now that I have enough oil pressure to tear the front end of the tractor completely off, I want to upgrade the camshaft gear. I"m told using a loader with the original camshaft gear is risky. I have found from a local salvage yard a 6664-DB gear for $45, which I"m told is the best gear possible. I need some good instructions on replacing that. Ideally I would like to remove the front cover and put a gear puller on it and jerk it off, no pun intended. I would really like to avoid removing the cam shaft itself, unless it is really easy. Any help would be really appreciated.
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati
... [Read Article]
Latest Ad:
[More Ads]
