Re: stuck M
Posted by Janicholson on August 25, 2012 at 10:46:29 from (199.17.6.66):
In Reply to: stuck M posted by kennell on August 25, 2012 at 10:19:36:
The head gasket cost less new than the time it will take for all the people on here to tell you to buy a new one and use spray on copper coat both sides one even coating. (((that is if there were consultation charges.))) The used gasket cannot crush to conform with the micro changes in the positioning of the head. The time it takes to replace the used gasket with a new one when it leaks (and you are unsure if it is that, or a cracked bore behind the sleeve), is not worth the cost of the new gasket. Jim
