Re: Would an old Farmall do the job for me??
Posted by Zachary Hoyt on August 25, 2012 at 13:33:58 from (184.12.70.98):
In Reply to: Would an old Farmall do the job for me?? posted by MO Farmall on August 25, 2012 at 11:36:25:
I have an H with a McCormick #31 loader with a blade and it is great for pushing snow. For what you need to do I agree that an H would be more gas efficient than a Super M but if you're only going to be mowing 10 acres and plowing the drive you won't be going through enough gas with any tractor to make a big difference either way. If you like the SM I would say go for it, they are certainly a 'classic' tractor and they're quite easy to work on if you are at all mechanically inclined. You will save all kinds of money over buying a new tractor, although it will probably require more frequent tinkering.
Zach
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
