Re: The Regular lives!
Posted by Tom Fleming on August 25, 2012 at 15:19:44 from (173.233.7.210):
In Reply to: The Regular lives! posted by Tom Fleming on August 25, 2012 at 10:44:59:
Thanks all. I have to order the fan belt or cut/splice one of the F-20 belts I have on the shelf. I had the timing advanced all the way, but I may be a tad off. I need to either figure out what is going on with the carb or find someone who can work on these. I bought parts for it, and cleaned it out good, but this is the first one of these I have ever done, and no one around to coach me.
I have the original steel front and rear, but for now, the rubber works better for moving it around.
One thing for sure, I am pleased, and will continue to fix things on her. I wish I lived closer to a few of you. I can make an F-4 mag sing, and my F-20 anbd F-12 get right on it. This one, with the E4A and the Ensign design carb has me baffled a bit................
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
