Re: Farmall A Snow/Grader Plow Question
Posted by Ol' Gimpy on August 25, 2012 at 15:46:42 from (74.67.127.235):
In Reply to: Farmall A Snow/Grader Plow Question posted by bordermen on August 25, 2012 at 05:26:25:
IH built an adapter setup for use with the 1A-60 blade unit,using a spring assited hand lift lever and matching linkage in lieu of the "Touch-Control" regular lift.The 1A-60 Operators Manual will show the unit.May be able to put one together,as I have several blades here,but,again,more,your location would likely be a factor.
