Re: Radiator leak on Sh
Posted by DeltaRed on August 26, 2012 at 08:06:27 from (67.6.225.104):
In Reply to: Radiator leak on Sh posted by VA Gasman on August 26, 2012 at 05:03:31:
"Dike" by Conklin is a good product that WORKS.However,this winter you should tear it down and fix it right.A seam like that can split under pressure-kinda ruins your day when that happens.
