Re: TA linkage
Posted by Janicholson on August 26, 2012 at 08:08:18 from (96.24.99.126):
In Reply to: TA linkage posted by bill b va on August 26, 2012 at 07:41:35:
The pins and clevises in the linkage need to have tight running clearance. Little wear is permitted.
Measured, .005 to .008 is OK per pivot.
The clutch pedal should have 1 inch of free travel from fully up, to the point of first pressure (freeplay). as the pedal is pushed farther, the main clutch will fully release (usually about another 1.25" or a little less. At that point the TA clutch should start to disengage. and it should be fully released (again at about 1" further travel). This is the way it should act, it is not the adjustment procedure. Jim
