I haven't touched those parts in a while. I had thought there were flat washers, but the parts catalog doesn't list any, so evidently not. The catalog lists lock washers for the 2 long studs at each end. The short middle stud is a special case. Do NOT put a lock washer on it. More importantly, make sure you are using the correct stud. The stud is hollow in the lower end and there is a hole in the side that meets the hole from the hollow end. This hollow stud is the oil feed to the rocker arms. Do NOT substitute a plain stud or a bolt for the hollow stud. Also, go easy tightening the middle nut. The hollow stud is weaker than a solid one and easy to twist off.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
