Posted by Janicholson on August 26, 2012 at 17:08:17 from (96.24.99.126):
In Reply to: Super H creeper gear posted by Adam Simcock on August 26, 2012 at 15:23:15:
Not a true creeper. Using a hydraulic pump, using a motor an chain reduction to drive the belt pulley as a power in, while blocking the clutch down worked as a non draft creeper on many tractors. A low first gear was an option, but it was slower, not creeping. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
