Re: 300 starter/wiring problem
Posted by Janicholson on August 26, 2012 at 17:12:05 from (96.24.99.126):
In Reply to: Re: 300 starter/wiring problem posted by Zachary Hoyt on August 26, 2012 at 13:07:59:
Try wiring the one on it with the Bat term next to the S!! It might just work well. If the original had no connect to the coil from the I terminal, it would not be an issue. You can use the S only relay. Jim
