Char-lynn on M, super M or MTA
Posted by Bryce Andreasen on August 26, 2012 at 19:57:14 from (66.241.163.42):
Has anyone mounted the pump anywhere besides the mounting bracket off the governor? Putting on an MTA gas/distillate and hate to cut the radiator shroud. It looks like i could make a bracket to sit up higher and use the same belt to run the alternator. I know i would have to disconnect the radiator hose, and it should be turning the correct direction. I think there should be enough room to put the reservoir directly ontop of the pump. Just curious if anyone had done this before without butchering the tractor.
