Posted by gene bender on August 26, 2012 at 20:15:23 from (67.55.226.123):
In Reply to: 49 supera posted by redpokadot on August 26, 2012 at 17:48:43:
That screw goes into the hex brass screw which screws onto the threaded end of the condensor in side the mag where that brass screw fastens to the condensor is a wire coming from the coil and another wire going to the points. The screw holdsthe wire coming from the sw to ground the mag to stop the engine. So tighten the hex part. Dont tighten the screw head until the wire from the sw is connected. If you take the cap off over the coil you can see the wires and can check to make sure they are not grounded. Have you removed the mag from the tractor as it mite be out of time 180 and check the wires going to the plugs to see they are in the correct position. Have you replaced the points if you took off the cover the wrong place the rotor mite be out of time also. Removing the cap and turning the engine over you can see the rotor snap then make sure its firing at the tower where the wire goes to the plug.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
