Re: TA linkage
Posted by riverbend on August 26, 2012 at 20:30:13 from (184.12.40.14):
In Reply to: TA linkage posted by bill b va on August 26, 2012 at 07:41:35:
I have had an on going problem with the TA clutch in my 350.
The new pressure plate was coil bound when it was bolted up, i.e. not much use. No amount of adjustment will make it work right. The TA clutch actuator shaft that came with the tractor had been cut and rewelded. An original ( 300 ) shaft works better, but it is still not right.
After this season is over I'm gojng to split the tractor again to see what the problem is. I suspect a bad pressure plate.
Greg
