Re: F12 Rear Steel
Posted by Ron W on August 26, 2012 at 21:05:45 from (24.247.83.82):
In Reply to: F12 Rear Steel posted by IAtractorKid on August 26, 2012 at 19:38:52:
It depends on the rear steel. Early Waukesha rear steel wheel has a small cast iron hub, they go for $850 for a good set that is not cracked. The later type is stamped steel with cast iron spreaders welded on them (the most common type). They go for $350 to $500. Front cast iron double steel are worth $250-300 for the pair; the early waukesha stamped steel single front (looks like to pie tins put together) are pricy at $1500 to $2000 for the wheel. They wore out fast and were too light to keep the front end down; didn't last long. Hope this helps!
