Re: stuck M
Posted by dej(Jed) on August 27, 2012 at 05:43:13 from (141.189.251.1):
In Reply to: stuck M posted by sflem849 on August 26, 2012 at 18:56:12:
If the gasket is intact I would reuse it. Simply add some High Temp permatex to it. Also torque it down about 5 psi over spec. Probably the biggest issue I would have would be the rings on 2 and 3. I would check to make sure they are flexing as they should be. Maybe you have done this already though.
