Re: Farmall H4 Magneto
Posted by Paul from MI on August 27, 2012 at 18:40:30 from (204.106.250.243):
In Reply to: Farmall H4 Magneto posted by MarkinOhio on August 27, 2012 at 07:13:44:
Glad you found the problem. Buddy of mine has had problems with a restored WW II jeep not running right over 35mph. for the last two months. Turned out to be a weak spring on the points, so you just have to check it all.
