Re: Farmall H4 Magneto
Posted by Hendrik on August 28, 2012 at 00:05:17 from (194.53.253.51):
In Reply to: Re: Farmall H4 Magneto posted by sflem849 on August 27, 2012 at 20:12:26:
Magnetos have a built in coil with a removable cover. This cover has some electrical parts incorporated which complete the path for the electric current from the coil to the cable that goes to the center of the distibutor cap.
Apparently, continuity of this path was sensitive to heat. A good reminder; I would never have thought of this failure mode.
