Re: How to remove an H steering wheel without damage
Posted by D Slater on August 28, 2012 at 05:10:09 from (184.15.7.159):
In Reply to: How to remove an H steering wheel without damage posted by Zachary Hoyt on August 27, 2012 at 18:30:32:
Sometimes heat is needed even with a puller on real tough ones but with it there's a chance the spokes will loosen in the hub on a steering wheel removed for reuse. If you don't have a heavy puller that will close that small a split type heavy duty bearing remover used with a puller can work.
