Re: How to remove an H steering wheel without damage
Posted by WOpp on August 28, 2012 at 06:18:05 from (75.234.14.213):
In Reply to: How to remove an H steering wheel without damage posted by Zachary Hoyt on August 27, 2012 at 18:30:32:
If you are going to use a puller, which is what it takes, put something between the puller and the steering shaft or you will damage the shaft to the point where the nut will no longer fit. I learned that one the hard way on my SMTA.
