Re: F-20 with water in cylinder
Posted by El Toro on August 28, 2012 at 06:20:01 from (108.3.143.30):
In Reply to: F-20 with water in cylinder posted by pdinius001 on August 28, 2012 at 06:02:48:
They used wet sleeves in those engines and should be easy to rebuild. I would have the head magna-fluxed to make sure its not cracked. Look for cracks in the engine block. Checked the cylinder head to make sure it isn't warped.
You could try replacing the head gasket and torque the head starting in the center and working out in both directions. Use about 3 steps when doing this until you reach the max torque. Once you have the engine started and heated up I would go over the max torque one more time. Don't loosen any. Hal
