Re: 450 tach cable
Posted by Janicholson on August 28, 2012 at 09:41:49 from (199.17.6.160):
In Reply to: Re: 450 tach cable posted by P and R Pete on August 27, 2012 at 16:08:46:
Shine a good light in there, wipe out excess grease to see the teeth realy clearly. That gear is not usually at fault. There should be a threaded collar on the #1 position of the pic that holds the cable in the drivven gear. It may be off the broken end, or just not shown in the pic. Jim
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
