Re: F-20 with water in cylinder
Posted by oldiron29 on August 28, 2012 at 14:47:39 from (74.88.11.200):
In Reply to: F-20 with water in cylinder posted by pdinius001 on August 28, 2012 at 06:02:48:
If you wick out the water with paper towel. Crank engine to TDC #2 and remove manifold. Let it sit with water in jacket if water comes out valve ports the crank or leak is in the head. If water fills cylinder Than it is in the sleeve or gasket. oldiron29
