Re: Starter Dragging
Posted by oldiron29 on August 28, 2012 at 17:47:16 from (74.88.11.200):
In Reply to: Starter Dragging posted by LMJ on August 28, 2012 at 15:30:30:
LMJ, I have many F-14 I must say I have rebuilt all the fuel pumps first because fuel to carb is the first thing that has to ne good. The push rod to pump can cause poor fuel flow if it is worn. I you have good coil in your mag spark should be ok also check your points. After that it is all about float in carb adjustment. I must say not one of mine is the same. Some like a little choke and others no choke. The one I never did anything to starts the best. So I guess that means I still don"t know how to adjust them right. oldiron29
