Re: Hydraulic pressure
Posted by twopop on October 11, 2000 at 06:36:33 from (208.209.103.43):
In Reply to: Hydraulic pressure posted by Bob Beckman on October 11, 2000 at 03:34:30:
the hyd.cylinders you are talking about are made to withstand 2500 psi safely.without leaking but is not necessarily a working pressure.most tractors today are set for 2250 psi.the older tractors used less pressure since they were not required to lift 6 row equip. or 2000 lb hay bales.1200psi is more than enough to lift a disc or any other equipment you can pull with a C
Post A Followup
: Re: Re: Hydraulic pressure
