Thanks for the info. Would that also explain the four bolt holes on the right side of the head? Two verticaly on the front quarter and two on the rear quarter. A coil was bolted to one of the rear holes but we removed that. Dad hadn't noticed the bolt holes or know what they were for. That may be where the gas tank bolted on at? I think the rear bolt holes are right below the hole in the hood.
Does this mean the hood is from an older tractor or did all the hoods have this hole so two types didn't have to be made?
This post was edited by Matt E. at 09:53:18 08/29/12.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
