Re: Voltage regulator tutorial ?
Posted by Brownie 450 on August 29, 2012 at 15:21:01 from (66.43.241.198):
In Reply to: Voltage regulator tutorial ? posted by riverbend on August 29, 2012 at 13:49:16:
The relay that is normally open [NO] closes when the gen starts to produce more than battery voltage.
The normally closed [NC] relay is supposed to start pulling open when voltage reaches around 6.5 volts.
This is the relay which "grounds" the field. If the regulator base isn't grounded well, the field relay can't send current/ voltage from the generator F terminal to ground.
You might try a little crocus cloth on the field relay contacts to burnish them.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
