Re: 450 fan- can it truly be...
Posted by Owen Aaland on August 29, 2012 at 19:36:20 from (216.47.32.166):
In Reply to: 450 fan- can it truly be... posted by P and R Pete on August 29, 2012 at 18:45:17:
You may want to replace both belts a the same time. You will need to completely loosen the adjustment sheave for the fan belt. The generator belt can then be slipped under the fan belt and you should be able to move it over one fan blade at a time.
