Re: 2 cyl wisc engine on Model 66 baler
Posted by Lmack on August 29, 2012 at 20:31:12 from (24.131.58.167):
In Reply to: 2 cyl wisc engine on Model 66 baler posted by Va Gasman on August 29, 2012 at 18:15:03:
The oil could have drained down during the set up time and you did not run it long enough for the valve stem to get well oiled again. It was also probably open during the set up and had a build up of crud.
